Hi everyone,
I have a little problem with setting appearance of the infragistics ultra numeric editor so it always looks like textbox. Under Windows XP with default and classic theme, out of the box ultra numeric editor looks just like ordinary TextBox (with the exception of PromptChar but that is not something what I am concerned with). If I run the same application in Windows Vista, ultra numeric editor will have a flat border (as in Windows XP default theme) whereas TextBox will have a different appearance (similar to the Infragistics.Win.EmbeddableElementDisplayStyle.WindowsVista display style).If I set the ultra numeric editor's DisplayStyle to "vista look" then control will look different under Windows XP.
How can I preserve correct appearance under Windows XP and still have correct appearance (same as TextBox) under Windows Vista ?
Thanks in advance.
This is a little odd. If you don't change any of the default settings, the control should be drawing using the Windows theming API, which will presumably look just like a text box. I'm not sure why it's not doing this.
I recommend that you Submit an incident to Infragistics Developer Support so they can check this out.
