How do I add a line separator to a list of items in a UltraCombo or UltraComboEditor? Although a very simple implemention seems to be adding a text/line with dashes etc. and write code on selectionchanged event to not allow selection. But is there something more elegant? It should be similar in appearance to the MRU List.
Thank you very much chandrasr!!
Here you go
public class UltraCmbEdLnSepDrawFilter : IUIElementDrawFilter
The following code needs to be included in your main form hosting the comboeditor
Does any one know how to implement separator for UltraComboEditor using DrawFilter..
-Takumi
Thanks, Mike.
We had looked at MRUList property but that does not satisfy our requirement. The requirement is to group some elements and separate them by drawing a line in a comboeditor. We wanted to keep Draw Filter as the last option if there was none other available. Have implemented it now using Draw Filter, works fine. Thanks.
