1500
SelectionDrag event with HeaderClickAction set to SortMulti
I need to handle the UltraGrid.SelectionDrag event. The HeaderClickAction (UltraGrid.DisplayLayout.Override.HeaderClickAction) property is set to SortMulti. The SelectionDrag event is not raised when I start dragging a column. However when I change HeaderClickAction to "Select" the event starts raising.
Why is that? Is there I way the SelectionDrag event is raised when I start dragging a column, when HeaderClickAction event is set to SortMulti?
Vitaly
