40
UltraWinChart 6.2 plot against Y2 axis.
Is there a simple way to plot on Y2 axis in 6.2? I am adding points manually to each series as NumericDataPoints:
Imports Infragistics.UltraChart
Dim numSer As New Resources.Appearance.NumericSeries
For point As Integer = 0 To maxCount
numSer.Points.Add(New Resources.Appearance.NumericDataPoint(someValue,someLabel, False))
Next
Me.UltraChart1.Series.Add(numSer)
Thanks!
  • 28496
    you can create a composite chart with two chart layers, each one using a different Y axis. it's not really simple, but it works.
