750
Port to Infragistics
I would like to port my application to completely use the infragistic controls....here is "recommended" way to change a System.Windows.Forms.TabControl to use UltraTabControl
or change System.Windows.Forms.Button to be UltraButton
etc....
What's the best approach?....recreating all the controls would just kill me.
 thanks
 Gene
  • 17259
    You can replace every place written System.Windows.Forms.Button to Infragistics.UltraWinEditors.UltraButton, but maybe your designer had set some properties that MS has and Infragistics doesn't (Usually the opposite is true), so you'll still have some work to do.
    I think the best approach is to create a CustomControl that inherits MS's button or Infragistics's button. If you do that, you have to change your code in much less places if you decide to change the button type.
