115
UltraChart
How to make the 2nd Columns of my Tables as the <ITEM_LABEL>
  • 28496
    what type of chart are you using?  typically, the column names are used as the item labels, and the first string column is used for series labels.  this behavior can be switched, though, by setting chart.Data.SwapRowsAndColumns = true.
  • 469350
    Moved post to the Chart forum.
