I created application, let's name it app1 using Infragistics 11.1, and bind Calendar Info to MySql database, and populated with more than 1000 appointments. Now I created new application app2 (different project name comparing with app1) using Infragistics 13.1, and I want to use same appointments I used in app1. But when I connect app2 to the same database in MySql I used in app1, I cannot see appointments in app2 (and still see them in app1). How can I use those appointments in my new app2 ???
PS I load all data from mysql in dataset in app2 (I count 1057 rows). Also, the app owner is the same in app2 as well as in app1.
Hello Divac,
If you need any additional assistance don’t hesitate to ask.
Regards
It is very difficult to guess what cause your issue without to see your code/sample that reproduce the problem, but for sure you can use your appointments in the new application. I try to reproduce your scenario using two different samples (the first one with version 11.1 and second one with version13.1), but everything works properly (please take a look at the attached video file). If you think that I didn`t reproduce your scenario, please feel free to send us sample that reproduce your scenario and I`ll be glad to research it for you.
If you have any questions, do not hesitate to write me
