1125
How to set the value of an Ultracombo to null when it's bound to a string?
Hi
I've come across a bit of odd behaviour in the ultracombo:  When it is bound to field of a nullable type (e.g. a nullable int), and AllowNulls is set to true then when you blank the combo's text via the UI the property the control is bound to is correctly set to null.  However, if the combo is bound to a string field then when you clear the text from the combo the underlying property is not updated at all.  The combo allows you to move the focus away and is blanked, but the field underneath is still retaining the original value.
Is there a way to change this behaviour?
