I have a ultrapanel in a form, and I have to add three Ultraexpandablegroupbox controls such that each of them can resize automatically based on the space in the ultrapanel, like if grpbx#2 is collapsed then grpbx#1 & grpbx#3 should occupy the space and other such combinations. I saw the video on youtube but when I dock the grpboxes to fill, all of them occupies the entire ultrapanel. I even tried with grpbx#1 docked to top, grpbx#2 docked to fill & grpbx#3 docked to bottom, here grpbx#1 & grpbx#2 behaves as it should but cant make grpbx#3 occupy complete space when other two are collapsed.
I am open to use any other control other than ultrapanel if required.
I am glad to hear that you were able to find a solution for you. Other option that you could check is to use standard MS TableLayoutPanel
http://code.msdn.microsoft.com/windowsdesktop/TableLayoutPanel-Sample-f1504098
Thanks Hristo, your suggestion got me thinking in a new way. I docked the 1st Expandable Groupbox to a panel with "Fill" and the rest two in another panel with 2nd Expandable GroupBox to "Top" and 3rd to "Fill". And Panel#1 to Top and Panel#2 to Fill.
As I didn't want to play with heights, I manipulated the dock properties and it worked for me.
Below is the code for the two expandable Groupboxes in Panel#2. This helped me achieve my functionality but can I make this better, pls suggest?
private void rearrangeGrids() { if (ultraExpandableGroupBox1.Expanded == true && ultraExpandableGroupBox2.Expanded == false) { ultraExpandableGroupBox2.Dock = DockStyle.Bottom; ultraExpandableGroupBox1.Dock = DockStyle.Fill; } if (ultraExpandableGroupBox1.Expanded == true && ultraExpandableGroupBox2.Expanded == true) { ultraExpandableGroupBox2.Dock = DockStyle.None; ultraExpandableGroupBox1.Dock = DockStyle.None; ultraExpandableGroupBox1.Dock = DockStyle.Top; ultraExpandableGroupBox2.Dock = DockStyle.Fill; } if (ultraExpandableGroupBox1.Expanded == false && ultraExpandableGroupBox2.Expanded == false) { ultraExpandableGroupBox1.Dock = DockStyle.Top; ultraExpandableGroupBox2.Dock = DockStyle.Top; } if (ultraExpandableGroupBox1.Expanded == false && ultraExpandableGroupBox2.Expanded == true) { ultraExpandableGroupBox1.Dock = DockStyle.Top; ultraExpandableGroupBox2.Dock = DockStyle.Fill; } }
Hello ,
What you could do in your cases to dock all panels to the top, then after group was expanded/collapsed to adjust the height of each expanded group in this panel, in order to fit available space.
