How do I get the calculated TaskEndTime, as calculated by the TaskStartTime, Duration, and constraints?
I am using DataBinding and the TaskEndTime reflected in my underlying data source is not being updated to reflect the "Finish" column value displayed in the UltraGanttView
Hello Cheo,
I create a private case for you with Ref. CAS-121229-V9G0T8. You could find this case at: Infragistics.com -> Accounts -> Support Activity. Please send us your sample through this private case. Please zip your files and upload it using IE8/9
if you have any questions, feel free to write me
Regards
Hi Georgi,
I am happy to send you the complete project, but I'd prefer not to share it publicly on this forum. Can you please provide an email address to send to, or otherwise write me directly?
I`m not sure that I understand your scenario, but if you modify your TaskStartTime or Duration through the UltraganttView control, then the TaskEndTime (Finish column) should be update it automatically with appropraite date depending of your StartTime and Duration. The mentioned issue, could be reproduce it if you modify your TaskStartTime/Duration/TaskEndTime dicrect in the database, but wihtout any modifications in the AllProperties (binary column), because when you load your Task in the UltraGanttView control, some of the values will be extract from AllProperties field.
Maybe will be better to send us small smple that reproduce your issue and I`ll be glad to research it for you.
