I am binding the datagrid to an empty object instead of null and it now preserves the layout. Earlier , when i was putting the datasource as null then the layout was lost and even hidden columns were displayed.
While we are on groupby, can you advise how to do the following:
Group on a column when binding to datagrid. (i know this part)
and then within each group order by particular field (such as a date field) --> need help with this part
I am just checking about the progress of this issue. Let me know If you need any further assistance on this matter?
After you group your grid by desired column, you could order grid by column which you need and rows will be sorted within the group. Please see attached sample.
The second option pls which is easier..i just ned to order within the group and not the group column itself
