300
UltraGridExcelExporter. Value can not be null. Parameter name: key
Good day.
After exporting filtered grid into excel I receiving datasheet with
After you export the list to Excel, I get a list with the errors in the first column:
Error in first column
In programm, I have double-type values in this column. For example: 3; 33; 25.8
Why do I receive this error? Key value for this column is present and correct.
Code for export is very simple:
Infragistics.Win.UltraWinGrid.ExcelExport.UltraGridExcelExporter exp = new Infragistics.Win.UltraWinGrid.ExcelExport.UltraGridExcelExporter();
string filename = StartupPath + "\\tmp.xls";
exp.Export(my_grid, filename);
