I am assigning images to appointments in a Timeline control and am receiving "out of memory" errors. I have 3000 appointments loaded at one time, which is pretty typical for my application. I am looping through the appointments and loading each image from a filestream. Everything works for a period of time, but as I scroll through the control, I eventually get an "out of memory" error. I know it has something to do with the images because when I skip the code that loads the images, I don't get any errors.
Is there a better way to handle these images or do I need to forget about trying to load them? I am scaling each image down to 16X16, so it's not necessarily the size of the images that's eating up the memory.
Could you please upload small sample that reproduce the issue. Using versioin 12.1.20121.2135, I was not able to reproduce it. Also maybe you know that the product lifecycle of your version is expired. It means that we are not able to make any changes in this version. More details you could find at: http://ko.infragistics.com/help/product-lifecycle/
I am using 12.1 with your latest service pack installed.
Hello rehemann,
I try to reproduce your issue in a small sample using our latest available version 13.1.20131.2060, but without success. Could you please tell me what is your current version and do you have any installed service release and which one. Are you able to send us small sample that reproduce your issue. I`ll be glad to research it for you.
Regards
