I am using .NET 4.5 and Infragistics 2013.1
I have a WinGrid including about 140000 rows.
According to ANTS Profiler (see attached image) setting a previous found as selected row takes about 3 seconds.
Seems to be pretty much ...
Is there something I am missing?
Can you give me some advice for performance optimization, please.
Thomas
Thank you for the provided code snipped. I have reviewed it very careful and I noticed that you have some flags which you are managing in your Navigate method, and those flags are global variable. Here is what I think that happens in your case :
You have subscribe for some Grid’s events in which, based on your flags you are executing some piece of code (based on your code snipped I assume that you have subscribe for SelectChaged event of UltraGrid, and you should keep in mind that this event will occurs every time when call grdSAPMaterials.Selected.Rows.Clear(); or row.Seceted = true;). So the code of this events actually introduce your delay (again setting of row.Seceted = true; causes occurring of SelectChaged).
To demonstrate what I talk about, I have created very simple sample, where am printing duration of each operation of your code snipped. I have subscribed for AfterSelectChaged event of UltraGrid and have added following code to simulate long operation:
Thread.Sleep(3000);
Also I have added an option in the form which allows you to enable/disable firing of AfterSelectChaged. So run the sample and press “Search” button, and observe the duration of each operation when the AfterSelectChaged is disabled. Now mark “Subscribe for SelectChanged event and sleep for 3 sec.” CheckBox and observe the durations of the operations.
Please let me know if you have any further questions or if I am missing something.
