1440
Error when sort on formula column sometimes
 I am getting this exception sometimes when I sort on a formula column calcuated by the CalcManager.  It looks like this problem is related to the UltraGridLayout.Load(Stream stream, PropertyCategories propertyCategories) method.  It works fine if I don't load any layout to the grid.
Jason
All Events Information: 1 : Timestamp: 5/30/2008 2:19:00 AM
Message: Infragistics.Win.CalcEngine.UltraCalcException: Invalid reference //ultraGrid1/Main/(). Empty element encountered at location 18.
   at Infragistics.Win.CalcEngine.RefParser..ctor(String refName)
   at Infragistics.Win.CalcEngine.RefBase.CreateParsedReference()
   at Infragistics.Win.CalcEngine.RefBase.get_ParsedReference()
   at Infragistics.Win.UltraWinGrid.UltraGridRefBase.get_ParsedReference()
   at Infragistics.Win.UltraWinGrid.UltraGridRefBase.ContainsReferenceHelper(IUltraCalcReference inReference, Boolean isProperSubset)
   at Infragistics.Win.UltraWinGrid.UltraGridRefBase.IsSubsetReference(IUltraCalcReference inReference)
   at Infragistics.Win.CalcEngine.UCRecalcChain.RemoveSubsetReferences(IUltraCalcReference reference)
   at Infragistics.Win.CalcEngine.UltraCalcEngine.ProcessDeleteFormula(IUltraCalcFormula formula, IUltraCalcReference baseReference)
   at Infragistics.Win.CalcEngine.UltraCalcEngine.ProcessTopologicalEvent(QueueInfo item)
   at Infragistics.Win.CalcEngine.UltraCalcEngine.CleanTopologicalEventQueue(Int64 ticks)
   at Infragistics.Win.CalcEngine.UltraCalcEngine.Recalc(Int64 ticks)
   at Infragistics.Win.UltraWinCalcManager.UltraCalcManager.ReCalcInternal(Int64 ticks)
   at Infragistics.Win.UltraWinCalcManager.UltraCalcManager.ReCalc(Int64 millis)
   at Infragistics.Win.UltraWinCalcManager.UltraCalcManager.Infragistics.Win.CalcEngine.IUltraCalcManager.PerformAction(UltraCalcAction action, Object data)
   at Infragistics.Win.UltraWinGrid.SortedColumnsCollection.ProcessNewSortedColumnsHelper(SortedColumnsCollection newSortedColumns, Boolean fireEvents, Boolean groupBy)
   at Infragistics.Win.UltraWinGrid.SortedColumnsCollection.SetSortedColumn(UltraGridColumn column, SortIndicator sortIndicator, Boolean groupBy, Boolean clearExistingNonGroupByColumns, Boolean fireEvents)
   at Infragistics.Win.UltraWinGrid.UltraGridBand.SetSortedColumn(UltraGridColumn column, SortIndicator sortIndicator, Boolean clearExisting)
   at Infragistics.Win.UltraWinGrid.UltraGridColumn.ClickSortIndicator()
   at Infragistics.Win.UltraWinGrid.HeaderUIElement.EndDragHelper(Boolean cancelled)
   at Infragistics.Win.UltraWinGrid.HeaderUIElement.OnMouseUp(MouseEventArgs e)
   at Infragistics.Win.ControlUIElementBase.ProcessMouseUpHelper(Object sender, MouseEventArgs e)
   at Infragistics.Win.ControlUIElementBase.ProcessMouseUp(Object sender, MouseEventArgs e)
   at Infragistics.Win.Utilities.ProcessEvent(Control control, ProcessEvent eventToProcess, EventArgs e)
   at Infragistics.Win.UltraControlBase.OnMouseUp(MouseEventArgs e)
   at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
Category: General
Priority: -1
EventId: 1
Severity: Information
Title:
Machine: HK2638XP
App Domain: MarketWatch.vshost.exe
ProcessId: 5080
Process Name: C:\Documents and Settings\a456056\a456056_view_portfolio_monitor_1.2_dev\vob_portfolio_monitor\Frontend\bin\Debug\MarketWatch.vshost.exe
Thread Name:
Win32 ThreadId:5180
Extended Properties:
