There is "ShowToolTips" option in ItemSettings to enable/disable Tooltips but then the tooltip is always displayed.
Is there a way to display them only in case the text doesn't fit and is displayed shortened with ellipsis?
Thank you! I can't see the case in my support-activity area but I saw the Bugfix listed in the service release change log.
Hello dkress,
I am following up and wanted to inform you that your issue has been addressed in service release versions WinForms_13.1.20131.2079, WinForms_12.2.20122.2116. Let me know if you have any questions regarding this matter.
This service release is now available under your account at the Infragistics Website. To download the service release, log in to ‘Account’ and select ‘Keys & Downloads’. Select the appropriate tab for this product; then the license key. The available service releases (Hot Fixes) should now be listed on the page.
Thank you for contacting us.
I was able to reproduce the issue and have opened a private case for you so that I can link it to this development issue. This way you will be notified automatically when the dev issue is updated. The case number is CAS-123760-F6F8Q6. You will see it located here: https://ko.infragistics.com/my-account/support-activity
