Hello I will need guide to make this graph
The code to create this Line chart.
I tried by myself but I got stuck at some points.
I need to do this>
On step 1) Is just an image waiting to drag a parameter
( object that is constantly updating )
2) when a parameter is dragged then I had to create a legend and I subscribe to an event parameter.Updated
At this point I tried to create an empty serie for this parameter (blue)
3) on Parameter Updated I get a new value pair of this parameter (eg: (12:34 hh:mm, 90%))
On this event I have to add this point (pair) to the serie corresponding to the parameter.
Then I will have to remove old points of the serie ( I will always have the ones in the range between max and min hours:min)
When time pass I will have to change the time range
This is some info constantly updated, there is a subscription for each parameter and at the update one new point is added, and an old one is removed.
Could be up to 20 series
I hope you understand and can guide me..
thank you very much
Hello facundomensajes,
facundomensajes said:The code to create this Line chart
facundomensajes said:1) Is just an image waiting to drag a parameter
facundomensajes said:... when a parameter is dragged then I had to create a legend...
CompositeLegend myLegend = new CompositeLegend();
myLegend.ChartLayers.Add(myScatterLayer);
myLegend.Bounds =new Rectangle(88, 2, 11, 15);
myLegend.BoundsMeasureType =MeasureType.Percentage;
myLegend.PE.ElementType =PaintElementType.Gradient;
myLegend.PE.FillGradientStyle =GradientStyle.ForwardDiagonal;
myLegend.PE.Fill =Color.CornflowerBlue;
myLegend.PE.FillStopColor =Color.Transparent;
myLegend.Border.CornerRadius = 10;
myLegend.Border.Thickness = 1;
this.ultraChart1.CompositeChart.Legends.Add(myLegend);
facundomensajes said:3) on Parameter Updated I get a new value pair of this parameter. On this event I have to add this point (pair) to the serie corresponding to the parameter. Then I will have to remove old points of the serie
Hi Georgi, Thanks a lot for your reply.
I didnt uploaded code, sorry about my misspelled :) not very good with English, I ve just added images of how I expected the graph will be.
Thank you for your code sample I will take a look at it. Thanks
Regards
Could you please send us your screenshot with expected graph, because we didn`t receive it. Please zip your files and try to upload it through "Option" tab. Also if you have any questions related with my sample, please do not hesitate to write me
