110
status bar when ribbon used
Does anybody know how to get the status bar that is docked bottom to properly appear within the Main UI border when the toolbarsmanager control is set to display the ribbon? If I:
1. add a toolbars manager control to the form and set the ribbon to show.
2. add a status bar to the form and dock bottom.
 . . . then the status bar properly appears within the main UI with a border around the entire application.
But when I set the IsGlassSupport to False so that the UI properly styles the entire application, then the status bar "hangs" outside of the main application border and looks really ugly depending on which appstyle is loaded. The status bar should remain connected to and embedded within the main form rather than appearing as a stand alone control that is taped together at the bottom of the form.
