Recently we started using appstyling and loading isl files to apply the themes. But we are facing a issue related to painting of the form. The form is not painted correctly when we restore it from the minimized state. I have attached a sample of the non painted form. The form again gets painted when I try to resize it.
This issue is happening only for restoring from minimized state and not for launch of new form and only when the appstyling is applied and not when it is turned off.
Can you suggest some actions which can rectify this problem.
Hi Puneet,
I've never seen an issue like this before. Which Isl file are you using? Is it one of ours or one of your own?
What version of the Infragistics assemblies are you using? You might want to try getting the latest service release to see if that helps. How to get the latest service release - Infragistics Community
Are you able to reproduce the problem in a small sample application? If so, you could post it here and we would be happy to take a look and find out what's going on.
Attaching another sample of different form.
