210
PDF export in Chinese with UltraGridDocumentExporter
Hi
I try to export the content of an ultrawingrid in PDF using this code :
private static void Export(UltraGrid grid, Stream target, GridExportFileFormat format)
      using (var exporter = new UltraGridDocumentExporter())
                exporter.Export(grid, target, format);
This works fine in the English version of the software, but not in the Chinese one.
I get an exception : Object reference not set to an instance of an object.
The stack trace is the following:
   at Infragistics.Documents.Reports.TTF.Font.Subset(Boolean regular)
   at Infragistics.Documents.Reports.PDF.Font.EmbedData()
   at Infragistics.Documents.Reports.PDF.PdfDocument.Generate(Stream stream)
   at Infragistics.Documents.Reports.Report.Report.Publish(Stream stream, FileFormat format)
   at Infragistics.Win.UltraWinGrid.DocumentExport.UltraGridDocumentExporter.EndExportInternal(UltraGridExporterHelper ultraGridExporterHelper, Boolean canceled)    at Infragistics.Win.UltraWinGrid.DocumentExport.UltraGridExporterHelper.Infragistics.Win.UltraWinGrid.IUltraGridExporter.EndExport(Boolean canceled)    at Infragistics.Win.UltraWinGrid.UltraGrid.Export(IUltraGridExporter exporter)    at Infragistics.Win.UltraWinGrid.DocumentExport.UltraGridDocumentExporter.Export(UltraGrid grid, ISection section)    at Infragistics.Win.UltraWinGrid.DocumentExport.UltraGridDocumentExporter.Export(UltraGrid grid, Report report)    at Infragistics.Win.UltraWinGrid.DocumentExport.UltraGridDocumentExporter.Export(UltraGrid grid, Stream stream, GridExportFileFormat fileFormat)
I guess it's because the Chinese version uses Simsun font, instead of Arial in the English version.
But I need to use Simsun in Chinese, it is not possible as Arial is not well readable in Chinese.
How could I do the PDF export ?
Thanks for your help.
