I have a grid that works like an excel worksheet. I have turned the row border off. I want to set the right side of each cell to have a border color of black. This will cause a vertical line between each cell. In addition some of these cells need to have their bottom border set as well. How can I achieve this? I am assuming I will have to use a DrawFilter but I have no clue how to do cell by cell filters.
This works great, thank you.
Yes, using draw filter is one of the ways to solve your issue. I implemented it by getting the BeforeDrawBorders phase from the GetPhasesToFilter method for every CellUIElement and then drawing its right borders. As for how to draw the bottom border of a specific cell, the CellUIElemnt has Row and Column properties, with which you can determine if that is the cell you need.
I have attached a sample which demonstrates this approach. If you have any additional questions don’t hesitate to ask them.
