465
Threading with UltraListView
Hi
After reading hundreds of lines of text about threading and keeping everything thread safe I still do not get the following.
I have created on my main thread Items into a UltraListView, now at another time(not at creation) on another worker thread I want to update a subitem and or the text of the main column. So using a keyIndex linked to the MainColumn Item I use Dim intIndex as Integer = UltraListView1.Items.IndexOf(ItemKey) to return the required index if available. If a valid index is returned then I use Dim clmX as UltraListViewItem = UltraListView1.Items(intIndex) to make a reference to the object. When I need to set the Text property I use the Invoke as required on the clmX and pass it to the correct thread.
Now as I do not get a cross thread error when returning the IndexOf and no error when getting the clmX object is this method classed as thread safe?
Should I be using a Invoke to get the IndexOf or Invoking to get a UltraListViewItem for reference in the Dim?
-Paul
