755
How to Show a button only on some rows
Hi
whats the best way to show only in some rows a button ina a grid column,.
When setting the columnstyle to
Infragistics.Win.UltraWinGrid.ColumnStyle.Button
dann on each row i can see a button
to remove the button on the rows which shouldn't have one i was only sucessfull in hiding the button. but that looks strange because the place of the hidden column doesn't have the row background (s. attached image). Instead theres a grey rectangles. (s. image)
I also tried to not set the appearance of the column but change Style to button when the row is prepared but then i never see button.
Does somebody have any advice / example which has buttons only on some rows?
  • 23930
    I am just checking about the progress of you issue. If you have any additional questions, I will be glad to help you.
  • 469350
    Suggested Answer
    Set the Style on the cell, not the column. The InitializeRow event is usually a good place to do this.
