410
UltraListView Vertical Scroll Bar Overlapping Column
For some reason the vertical scroll bar is overlapping the last viewable column header.  You will see part of the column header on the right side of the scroll bar.  Is this a bug?  If so, has their been a fix put out?  If not, how do I fix it.
I do have a picture of the issue.  I have no way to post it from work onto a viewable website.  If you would like to see it, I can send the image via email.
Thanks for any help.
Later,
Mike
  • 185
    This is a pretty old topic but I noticed that this is still happening in winforms 2008 volume 3 with hotfix 2059 and the workaround that I got was to set the BorderStyle to "Solid".
  • 69832
    You should log an incident, and then you can attach the screen shot therein.
