Hi
UltraTree control is being used in one of our application. I want to disable the selection of the nodes when Mouse Left button is pressed on a node and Mouse is dragged down/up. It selects all nodes that are passed over.
Various combination of SelectType did not help much since I want to keep multi-node selection by Mouse Left Click + Control key.
Please suggest how to disable multi-nodes selection on Mouse Left + Mouse Drag.
I am just checking about the progress of this issue. Feel free to let me know if you need further assistance.
Why do you want to disable drag selection? I ask because the usual reason for this would be that you want to start a drag operation to drag the nodes. And if you do that (start a drag operation) then no selection will take place and problem solved.
