I am trying to create a column chart. I am building a datatable with several columns in it and I need to pick the column that will be represented along the X-axis. I can bind to my dataview with no problem, but I can't figure out how to show a column other than the first column in the datatable along the x-axis. How do I do that in code?
That is exactly what I needed! Thanks!
It is very difficult for me to guess what is your scenario, looking the screenshot. Are you using Composite chart ? Did you have a time to try my suggestion from previous response ?
Another possible solution for you could be :
ultraChart1.Data.UseRowLabelsColumn =true;
ultraChart1.Data.RowLabelsColumn = 2;
Please take a look at the attached picture. My data is represented correctly. The problem is that the labels along the X-axis are for the wrong column in my data table. 3145 is an autonumber field in my table and happens to be the first column in the table. I really want to display a customer name column instead. How do I pick another column in my bound datatable to be represented as the label? I cannot alter the structure of the table.
This is the sample
Hello Rehemann,
There are different approaches to solve this task. Maybe one possible solution could be if you are using DataBind method of your series. For example:
// DataSource
DataTable dt = new DataTable();
dt.Columns.Add("Items", typeof(string));
dt.Columns.Add("Miles Column", typeof(decimal));
dt.Columns.Add("Fillups Column", typeof(decimal));
NumericSeries columnSeries = new NumericSeries();
columnSeries.DataBind(dt,"Miles Column", "Items");
columnSeries.PEs.Add(new PaintElement(Color.Gold));
columnSeries.Label ="Miles [nm]";
Please take a look at the attached sample for more details and if you have any questions, feel free to write me
Regards
