When you've defined a Row Layout with Label position = Left (see attached file) it seems that:
ov.AllowColSizing = Infragistics.Win.UltraWinGrid.AllowColSizing.Free;
Is not working? 'Cause I can't size the Labels independantly from eachother...
Yeah great. That works just fine. Thanks!
Yes, you could set the column.RowLayoutColumnInfo.LabelPosition to None.
Hhmm... That's not going to look pretty.
Can I for instance make the label "Voorschrift" invisible (make it disppear somehow doesn't matter how), and only display the cell, but keep the labels "GPK" and "Dosering" + cells?
Well... you could change the column.RowLayoutColumnInfo.LabelSpan on one of the column and this would make the label span a different number of logical rows than the other one. But one would always be bigger than the other. You can't size these label's completely independently on a per-pixel basis, if that's what you are trying to do.
No i mean, I can't resize the label "voorschrift" independantly from label "GPK" (see screenshot). Or is this simply not possible?
