hi, i want to setup a parent-child relationship between a listbox and the ultragrid (win). I just want to be able to click on an item in the list and see its' details in the grid.
i've added the two tables to the dataset, created a relationship and added it. yet i'm not having the realtime filtering happen. what am i doing wrong?
this is my code for the parent listbox (of dates) which displays correct values. if you ask why i'm not using bindingsource for the grid it's because it yielded no results. here, i'm able to see the data in the grid as well. any help or tips would be greatly appreciated.
BindingSource bsDates = new BindingSource(); bsDates.DataSource = m_ds; bsDates.DataMember = "SNAPSHOT_DATES"; //name of table in ds lstBackupDates.DataSource = bsDates; lstBackupDates.DisplayMember = "snapdatedime"; lstBackupDates.ValueMember = "snapdatedime";
ultraGridSnapshots.DataSource = m_ds; ultraGridSnapshots.DataMember = "SNAPSHOTS"; //name of table in ds
DataRelation drSnapdate = new DataRelation("Snapdatetime", m_ds.Tables["SNAPSHOT_DATES"].Columns["SNAPDATEDIME"], m_ds.Tables["SNAPSHOTS"].Columns["SNAPDATEDIME"], false); m_ds.Relations.Add(drSnapdate);
sorry, i found the answer . just wasn't binding correctly. correct code is here. the child binding was not right.
bsDates.DataMember = "SNAPSHOT_DATES"; lstBackupDates.DataSource = bsDates; lstBackupDates.DisplayMember = "snapdatedime"; lstBackupDates.ValueMember = "snapdatedime"; BindingSource bsRows = new BindingSource(); bsRows.DataSource = bsDates; <================= datasource object above, not child table. bsRows.DataMember = "Snapdatetime"; <================ name of datarelation object ultraGridSnapshots.DataSource = bsRows;
