4341
Adding button in dropdown layout of UltraComboEditor
Hello Support Team,
I am using a ultracomboeditor where i would like to add a "add" button in dropdown layout such after checking the item when i click the "add" button then only the selected item should be update in the ultracomboeditor.
If in case above approach is not possible then can you let us know any other approach to achieve this.
  • 23930
    I am just checking about the progress of this issue. Let me know If you need my further assistance on this issue.
  • 23930
    Similar topic was discussed in the following thread:
    http://ko.infragistics.com/community/forums/t/85035.aspx#424577
    Please pay attention to the post from Mike where he has uploaded a sample, which shows how to modify the UltraCombo in order to make it look like there is a button.  Also I have modified this sample a little bit, so that it better fits your scenario.
    Please let me know if you have any additional questions.
    ComboFilterFix.zip
