Hi guys, just wanted to ask you what's the problem with legend in this chart, it displays the same value for both columns (pic attached). Legend format string is <ITEM_LABEL> - <DATA_VALUE: #0> and chart is column chart. I inserted one row with 3 columns (series name, article 1 value, article 2 value)
Hi, I haven't had a chance to try update, so I'll test it in next few days, and confirm this thread. But I have no doubt it's working fine :)
This issue has been addressed in service release versions WinForms_13.2.20132.2010, WinForms_13.1.20131.2095.
The following additional notes have been provided regarding this issue:
For those who have an active subscription, this service release is now available under your account at the Infragistics Website. To download the service release, log in to ‘Account’ and select ‘Keys & Downloads’. Select the appropriate tab for this product; then the license key. The available service releases (Hot Fixes) should now be listed on the page.
I have opened a private case for you so that I can link it to this development issue. This way you will be notified automatically when the development issue is updated. The case number is "CAS-128403-C8Z6V4". You will see it located here: https://ko.infragistics.com/my-account/support-activity
Let me know if you have any questions regarding this matter.
I'm seeing different things... can you attach the sample for this last post?
Mathew, Thanks. Just to inform you that I tried with binding datatable, and the problem occures again. I used simple code below:
DataTable mydata = new DataTable();mydata.Columns.Add("Series", typeof(string));mydata.Columns.Add("Column1", typeof(int));mydata.Columns.Add("Column2", typeof(int));mydata.Columns.Add("Column3", typeof(int));mydata.Columns.Add("Column4", typeof(int));mydata.Rows.Add(new Object[] {"New series", 150, 280, 80, 320});ultraChart1.DataSource = mydata;ultraChart1.DataBind();
Pic is in attachment.
