We need to replicate the VisualStudio MDI tabs behavior, i.e. we need to also be able to have the UltraDockManger.DragWindowStyle LayeredWindowWithIndicators in the UltraTabbedMdiManager, too.
The MdiManager sample does not seem to be able to do this, I have looked at pretty much all options.
This has been discussed before in this topic...
http://ko.infragistics.com/community/forums/t/68745.aspx
...but unfortunately the two links supplied (by Hristo) return 404 errors.
Here are those two links:
http://community.infragistics.com/forums/t/68741.aspx
http://community.infragistics.com/forums/t/67808.aspx
Sort of. There are more links in those postings which again return 404 errors.
But it seems the TabbedMdiManager does not support LayeredWindowWithIndicators, so it looks like there's no way of providing a consistent look and feel.
I have found some free dockable tab tools, some look pretty good. I'll probably just use one of those.
Hello Kenneth,
Here are the links you tried to access. Let me know if they help.
http://ko.infragistics.com/community/forums/t/68741.aspx
http://ko.infragistics.com/community/forums/t/67808.aspx
