I've set the dataschema manually in my ultraGrid1 (version: 12.1.20121.2135).
I have a List<Person> and every Person class has a List<Order>.
The datasource property of the grid is simply set at runtime, like:
List<Person> People = DummyRepository.GetPeople();
ultraGrid1.Datasource = People;
At first none of the people have an Order in their collection. At runtime the user can add an order. When the user does this I set the datasource again with People. But unfortunatly it doesn't show the added Order. I tried after setting the datasource property:
ultraGrid1.Rows.Refresh(Infragistics.Win.UltraWinGrid.RefreshRow.ReloadData)
ultraGrid1.Rows.Refresh(Infragistics.Win.UltraWinGrid.RefreshRow.RefreshDisplay)
And even:
ultraGrid1.Databind()
Nothing helps.
The only thing that seems to help is setting the datasource to null first and then setting the datasource to the collection. But then I have another problem, which I'm not sure I should get in to right now. You see I also have custom Row Layouts which I havent mentioned yet. But if I set the datasource to null the grid loses the custom row layout I designed in the designer at runtime.
I can set the datasource to null and keep displaylayouts by first saving and then loading the displaylayout, but... That shouldn't be the solution. Feels pretty forced to me. Besides I'll lose other properties like spacing between rows and such appearances.
So... How can I solve this?
Hey Mike,
Oh gosh! That is very simple. Well it must've been. Didn't understand why you guys would miss that. Turns out I've overlooked that parameter.
Thank you for looking into it in detail. I've marked your post as the answer.
Hi Danny,
I looked into this in detail, and it turns out to be very simple. The problem is that you are calling:
this.ultraGrid1.Rows.Refresh(Infragistics.Win.UltraWinGrid.RefreshRow.ReloadData);
instead of:
this.ultraGrid1.Rows.Refresh(Infragistics.Win.UltraWinGrid.RefreshRow.ReloadData, true);
The second parameter is for 'recursive'. By default, the operation is not recursive, so it doesn't refresh the child rows. So you just have to pass in true to refresh the child rows and it works fine.
DannyvdK said:I have a solution for my real world application now. I set an empty collection as datasource and then the filled collection. This seems to reset the cache and maintain the dataschema and custom row layouts. So I'm happy for now.
That seems like a reasonable workaround.
Mike,
You are spot on with the caching I think. That was my assumption too.
As a user of the gird however I really thought Refresh(ReloadData) forces the grid to get rid of the cache and reload the collection. But like you said, you don't want to break existing applications. So got to be carefull.
Good luck trying to find the solution to this. Keep me updated please.
I'd have to delve into this more deeply to find the exact cause, but I think it's clear that the grid is caching it's rows and since you are creating a new List<T> that contains the same instances as the objects in the original list, the grid is making the assumption that these objects are the same.
The grid probably shouldn't be making that assumption when it's DataSource is a completely new object and the Refresh(ReloadData) should probably be blowing away the old cache, but I'm not 100% sure if that's the correct behavior or why the grid behaves as it does now. There might be a reason for it, and changing this behavior could cause breakage in existing applications, so we need to be careful here with any changes we make on our end.
Creating new instances of the objects doesn't seem like an ideal solution, either, though.
I'm going to ask Infragistics Developer Support to write this up for developer review so we can investigate further and possibly get this fixed in a future service release.
