625
ILMerge for Infragistics 13.2 assemblies fails
In the context of some other thread I tried to ILMerge a set of Infragistics WinForms 13.2 assemblies.
Unfortunately the merging fails there. I did the following:
"\Program Files (x86)\Microsoft\ILMerge\ILMerge.exe" /copyattrs /allowMultiple  /log:mergeresults.txt /out:Merged.UI.Ext.dll /targetplatform:v4,"C:\Windows\Microsoft.NET\Framework\v4.0.30319" Infragistics4.Win.v13.2.dll Infragistics4.Shared.v13.2.dll Infragistics4.Win.Misc.v13.2.dll Infragistics4.Win.UltraWinGrid.v13.2.dll Infragistics4.Win.UltraWinEditors.v13.2.dll
I get the error:
ERROR!!: Duplicate type 'Infragistics.Win.UIAutomation.UiaProviderControlNativeWindow' found in assembly 'Infragistics4.Win.UltraWinGrid.v13.2'. Do you want to use the /alllowDup option?
An exception occurred during merging:
ILMerge.Merge: ERROR!!: Duplicate type 'Infragistics.Win.UIAutomation.UiaProviderControlNativeWindow' found in assembly 'Infragistics4.Win.UltraWinGrid.v13.2'. Do you want to use the /alllowDup option?
at ILMerging.ILMerge.MergeInAssembly(AssemblyNode a, Boolean makeNonPublic, Boolean targetAssemblyIsComVisible)
at ILMerging.ILMerge.Merge()
at ILMerging.ILMerge.Main(String[] args)
No output is generated. Adding the /allowDup option generates:
Unresolved assembly reference not allowed: UIAutomationProvider.
at System.Compiler.Ir2md.GetAssemblyRefIndex(AssemblyNode assembly)
at System.Compiler.Ir2md.GetTypeRefIndex(TypeNode type)
at System.Compiler.Ir2md.VisitReferencedType(TypeNode type)
at System.Compiler.Ir2md.VisitMethod(Method method)
at System.Compiler.Ir2md.VisitInterface(Interface Interface)
at System.Compiler.Ir2md.VisitModule(Module module)
at System.Compiler.Ir2md.SetupMetadataWriter(String debugSymbolsLocation)
at System.Compiler.Ir2md.WritePE(Module module, String debugSymbolsLocation, BinaryWriter writer)
at System.Compiler.Writer.WritePE(String location, Boolean writeDebugSymbols, Module module, Boolean delaySign, String keyFileName, String keyName)
at System.Compiler.Writer.WritePE(CompilerParameters compilerParameters, Module module)
Again not output is generated.
Isn't it possible to merge the v13.2 assemblies?
Best regards
Uwe
