I have a problem with the Ultra Form Manager. In the IDE, everything is fine and when you press play, everything is fine .But if one starts then the finished EXE nothing is displayed correctly.
Se Images IDE and EXE (left side IDE right side EXE)
Infragrastics ProfessionalVersion: 13.2.20132.1011
In what may lie?
Thanks for your help
frank
Hello,Thanks for your tip. It Works.Thank you very muchMerry Christmas and a Happy New Yearfrank
What I’ve noticed is that right form is smaller than the left one and It seems that this is related to the following MS Bug
http://connect.microsoft.com/VisualStudio/feedback/details/759413/winform-dialogs-displayed-differently-by-vshost-exe-and-exe-using-vs-2012-when-formborderstyle-set-in-form-codebehind
So you could try workarounds suggested there:
“Several workarounds are available. 1. In order to achieve runtime parity between NETFX 4.0 and 4.5 applications, manually change SubSystemVersion compiler option in the project file targeting NETFX 4.5, to a value lower that 6.00, see this article for details: http://msdn.microsoft.com/en-us/library/hh965708.aspx For example: add the following property to your project file: "<subsystemversion>5.01</subsystemversion> " Note that 64bits OS does not support all subsystem versions numbers. 2.In order to see the same layout when running the application from Visual Studio and as a standalone executable, for applications targeting FX below 4.5, disable vshost process when debugging: go to the project properties page, -> debug tab-> uncheck the "Enable the Visual Studio hosting process" 3. Set windows theme to "basic" on your development machine, then design time layout and layout during debugging with vshost enabled, will be the same as standalone runtime layout regardless of the target framework. If you are building a 4.5 application you would need to request the user to disable themes on the target machine or apply workaround #1. “
So please try those workarounds and let me know for the results. If no one of those workarounds helps, please post simple sample that demonstrate this issue in order to be able to continue investigating this issue further.
Hi Mike, my rescue
The difference is that easy to EXE (right) the edges are isolated tten both below and to the right.The UltraGroupbox and the grid is truncated within the Forms also right.Thank you for your help
Hi Frank,
I'm looking and looking, but I don't see any difference between the left and right images. What am I supposed to be seeing here?
