445
updating grid cell text
OK, so here is he situation.  I am dynamically creating grids and rows using InitializeRow event. In one cell I have an ultracombo with an editor button filled with values for that cell. Here is the code:
oSQL = "Select Description, CAST(LocationId as varchar(50)) as LocationId from Locations where AddressId='" & AddressId & "' "
                                        'oSQL &= " AND LocationBaseid IS NULL"
                                        If e.Row.Cells.Exists("Location Base") AndAlso Not IsDBNull(e.Row.Cells("Location Base").Value) Then
                                            oSQL &= " AND LocationBaseId='" & e.Row.Cells("Location Base").Value.ToString & "'"
                                            'oSQL &= " AND LocationBaseId='" & CType(e.Row.Cells("Location Base").EditorComponent, UltraWinGrid.UltraCombo).SelectedRow.Cells("LocationBaseId").Value.ToString & "'"
                                        ElseIf e.Row.Cells.Exists("Location Base") Then
                                            oSQL &= " AND LocationBaseId IS NULL" '& e.Row.Cells("Location Base").Value.ToString & "'"
                                        End If
                                        oSQL &= " order by Description"
                                        Dim cboType As New Infragistics.Win.UltraWinGrid.UltraCombo
                                        Dim EditorButton2 As Infragistics.Win.UltraWinEditors.EditorButton = New Infragistics.Win.UltraWinEditors.EditorButton("ShowQ")
                                        EditorButton2.Key = "AddLoc"
                                        EditorButton2.Text = "..."
                                        EditorButton2.Tag = Array.CreateInstance(GetType(String), 4)
                                        EditorButton2.Tag(0) = oRow("ColumnName").ToString
                                        EditorButton2.Tag(1) = e.Row.GetCellValue("InspectionId").ToString
                                        EditorButton2.Tag(2) = e.Row.GetCellValue("ItemId").ToString
                                        Dim utToolTip As New Infragistics.Win.UltraWinToolTip.UltraToolTipInfo
                                        utToolTip.ToolTipTextFormatted = "<span style='font-weight:bold; text-decoration:none;'>Click the '...' button to add a new" & LocationAlias & "<br/><hr/></span>"
                                        uttMain.SetUltraToolTip(cboType, utToolTip)
                                        cboType.ButtonsRight.Add(EditorButton2)
                                        AddHandler cboType.EditorButtonClick, AddressOf EditorButtonClick
                                        With cboType
                                            .DisplayMember = "Description"
                                            .ValueMember = "LocationId"
                                            .DataSource = eData.GetDataTable2(GetConnectionString, oSQL)
                                            .DisplayLayout.Bands(0).Columns("LocationId").Hidden = True
                                        End With
                                        cboType.DisplayLayout.ScrollBounds = UltraWinGrid.ScrollBounds.ScrollToFill
                                        If TestUserSetting("SGFontSize") Then
                                            cboType.DisplayLayout.Override.RowAppearance.FontData.SizeInPoints = cUserSettings("SGFontSize")
                                        Else
                                            cboType.DisplayLayout.Override.RowAppearance.FontData.SizeInPoints = 8.25
                                        End If
                                        SetDropDownWidth(cboType, "Description")
                                        e.Row.Cells(oRow("ColumnName").ToString).Column.Width = cboType.Width
                                        e.Row.Cells(oRow("ColumnName").ToString).EditorComponent = cboType
The editor button on the drop down opens a new form to allow for a new location to be created and added to the drop down. When I come back from the form I want the location created to be the value for the cell. Here is the code from the EditorButton click event:
    Private Sub EditorButtonClick(sender As Object, e As Win.UltraWinEditors.EditorButtonEventArgs)
        Dim curCBO As Infragistics.Win.UltraWinGrid.UltraCombo = sender
        Dim curButton As Infragistics.Win.UltraWinEditors.EditorButton = curCBO.ButtonsRight(0)
        Dim oSQL As String
        Try
ElseIf curButton.Tag(0).ToString = LocationAlias Then
                    Dim eRow As Infragistics.Win.UltraWinGrid.UltraGridRow = CType(e.Context, Win.UltraWinGrid.UltraGridCell).Row
                    Dim oForm As New frmLocation
                    oForm.AddressId = AddressId
                    oForm.txtAddress.Text = lblAddress.Text
                    oForm.ucboDescription.Text = eRow.Cells(LocationAlias).Text
                    If eRow.Cells(LocationAlias).Text <> "" AndAlso TypeOf eRow.Cells(LocationAlias).Value Is Guid Then
                        oForm.PrimaryKey = eRow.Cells(LocationAlias).Value.ToString
                    End If
                    If eRow.Cells.Exists("Location Base") AndAlso eRow.Cells("Location Base").Value IsNot Nothing AndAlso Not IsDBNull(eRow.Cells("Location Base").Value) Then
                        'SetSelectedRow(oForm.ucboLocationBase, "LocationBaseId", UCase(eRow.Cells("Location Base").Value.ToString))
                        oForm.LocationBaseId = eRow.Cells("Location Base").Value.ToString
                    End If
                    oForm.ShowDialog()
                    If Not oForm.PrimaryKey Is Nothing Then
                        Audit.SubRecordAudit(oForm.cboLocationType.Text, oForm.PrimaryKey, "Locations", clsAudit.SubRecordAuditTypes.AddRecord)
                        ISDirty = True
                        'oSQL = "Select LocationBase, Cast(LocationBaseId as varchar(50)) as LocationBaseId from LocationBases where AddressId='" & AddressId & "' order by LocationBase"
                        If eRow.Cells.Exists("Location Base") Then
                            Dim cboType As Infragistics.Win.UltraWinGrid.UltraCombo = CType(eRow.Cells("Location Base").EditorComponent, Win.UltraWinGrid.UltraCombo)
                            'eRow.Cells("Location Base").SetValue(DBNull.Value, True)
                            'cboType.DataSource = Nothing
                            'With cboType
                            '    .DisplayMember = "LocationBase"
                            '    .ValueMember = "LocationBaseId"
                            '    .DataSource = eData.GetDataTable2(GetConnectionString, oSQL)
                            '    .DisplayLayout.Bands(0).Columns("LocationBaseId").Hidden = True
                            'End With
                            'SetDropDownWidth(cboType, "LocationBase")
                            'cboType.DisplayLayout.ScrollBounds = UltraWinGrid.ScrollBounds.ScrollToFill
                            'eRow.Cells("Location Base").EditorComponent = cboType
                            SetSelectedRow(cboType, "LocationBaseId", UCase(oForm.LocationBaseId))
                            eRow.Cells("Location Base").SetValue(UCase(oForm.LocationBaseId), True)
                        End If
                        oSQL = "Select Description, LocationId from Locations where AddressId='" & AddressId & "' "
                        If eRow.Cells.Exists("Location Base") AndAlso Not IsDBNull(eRow.Cells("Location Base").Value) Then
                            oSQL &= " AND LocationBaseId='" & eRow.Cells("Location Base").Value.ToString & "'"
                        ElseIf eRow.Cells.Exists("Location Base") Then
                        End If
                        Dim NewLoc As String = eRow.Cells(LocationAlias).Text
                        eRow.Cells(LocationAlias).SetValue(DBNull.Value, True)
                        'curCBO.DataSource = Nothing
                        With curCBO
                        End With
                        curCBO.DisplayLayout.ScrollBounds = UltraWinGrid.ScrollBounds.ScrollToFill
                        SetDropDownWidth(curCBO, "Description")
                        EBClick = True
Here is my problem
                        SetSelectedRow(CType(eRow.Cells(LocationAlias).EditorComponent, Infragistics.Win.UltraWinGrid.UltraCombo), "Description", NewLoc)
                        eRow.Cells(LocationAlias).Value = oForm.PrimaryKey
                        EBClick = False
                    End If
                    If oForm IsNot Nothing Then oForm.Dispose()
What I get is not the Text description but the guid in the field that is hidden in the combo.
What am I doing wrong.
Any help would be great.
Thanks.
