I have a form set as a MDI container with a dock manager and an tabbed mdi manager. My goal is to prevent a group of panes from being anything but floating. I do not want the panes removed from the group or docked in any position. So far I set the AllowDockTop, AllowDockBottom, AllowDockLeft, AllowDockRight and CanDisplayAsMdiChild to False. This prevents the panes from being docked but it does NOT prevent them from being displayed as an mdi child. When I drag the group of panes all dock indicators are invalid drop locations EXCEPT for the center indicator which will make each pane in the group an MDI tab in my form. I want to prevent this from happening. I expected the CanDisplayAsMdiChild = False to prevent this but it does not.
How can I achieve this behavior?
Thanks.
Interesting, I just built a sample to send to support and this is only an issue when using the UltraDockWorspace and UltraTabbedMdiWorkspace from NCEK and not the UltraDockManager and UltraTabbedMdiManager on a normal win form...
Yes, setting CanDisplayAsMdiChild to False should prevent a pane from being docked as an mdi child. This may be a bug. I would recommend submitting the issue to the support group: http://ko.infragistics.com/gethelp.
