Hello -
I have an ultrachart [infragistics version 12.1] that displays weight for age. I have age on the X axis and weight on the y axis. I am using calloutAnnotations to display text on each data point as seen in the attached image file. But the problem is that the callouts overlap when x axis has almost same data point. Is there a way around it, something like AnnotationSmartLabelStyle that we have in DataVisualization.Charting.
I have set the Callout.Location.Type = Infragistics.UltraChart.Shared.Styles.LocationType.DataValues;
Rajesh
Hello Rajesh,
The code that I upload in my previous response is applicable for composite chart and custom layers . Please take a look at the end on myColumnLayer this is my custom layer. More details you could find in our documentation:
http://help.infragistics.com/Help/Doc/WinForms/2013.2/CLR4.0/html/WinChart.html
http://help.infragistics.com/Help/Doc/WinForms/2013.2/CLR4.0/html/Chart_Annotations.html
http://help.infragistics.com/Help/Doc/WinForms/2013.2/CLR4.0/html/Chart_Composite_Chart.html
Infragistics.UltraChart.Resources.Appearance.ChartTextAppearance chartTextAppearance1 = new Infragistics.UltraChart.Resources.Appearance.ChartTextAppearance();
chartTextAppearance1.ChartTextFont = new System.Drawing.Font("Arial", 7F);
chartTextAppearance1.ClipText = false;
chartTextAppearance1.Column = -2;
chartTextAppearance1.ItemFormatString = "My Text <DATA_VALUE:00.00>";
chartTextAppearance1.Row = -2;
chartTextAppearance1.Visible = true;
LineChartAppearance lca = new LineChartAppearance();
lca.ChartText.Add(chartTextAppearance1);
myColumnLayer.ChartTypeAppearance = lca;
Let me know if you have any further questions.
I have the same problem like Rajesh . I want to show annotations but currently they are overlapping each other .You can see in attached image.
URL for image [https://www.dropbox.com/s/1kq0907gn4kkhn6/ChartOverlapofAnnotations.JPG]
Georgi - We are using Custom layers in the chart. So does it support ChartTextAppearance ?. Couldn't find any article or posts related to this.
thanks
OK. Let me know if you have any questions.
Georgi : Will check this and let you know..Thanks
