I want the icon for UltraMessageBox like WinForms title bar icon. I have seen the previous post http://ko.infragistics.com/community/forums/t/44081.aspx for the same and does the steps suggested by your team member but doesn't seem to work. Please Can anyone help me out of this. This is too much important an urgent. The sample code is here.
Dim sMessage As String = String.Empty
Dim ulMessageBoxManager As New UltraMessageBoxManager
Dim objMessageInfo As New UltraMessageBoxInfo
objMessageInfo.Buttons = MessageBoxButtons.OK
objMessageInfo.Icon = MessageBoxIcon.Information
objMessageInfo.Caption = "Message"
objMessageInfo.TextFormatted = " <a href='" + My.Application.Info.DirectoryPath + "\MyLog.log'> " + My.Application.Info.DirectoryPath + "\MyLog.log</a>"
objMessageInfo.ButtonAlignment = Infragistics.Win.HAlign.Center
objMessageInfo.Style = Infragistics.Win.UltraMessageBox.MessageBoxStyle.Standard
objMessageInfo.ShowHelpButton = Infragistics.Win.DefaultableBoolean.False
If i call ulMessageBoxManager.ShowMessageBox(objMessageInfo), it works fine but it doesn't have title bar icon.
Dim objAssembly As Assembly = Assembly.Load("Infragistics2.Win.v10.3")
Dim objType As Type = objAssembly.GetType("Infragistics.Win.UltraMessageBox.MessageBoxDialog")
Dim objMethodInfo As MethodInfo = objType.GetMethod("InitializeDialog")
Dim objReturn As Object
Dim objParams(0) As Object
objParams(0) = objMessageInfo
Dim ObjData As Object = objMethodInfo.Invoke(objReturn, objParams)
Dim objMsgBoxDialog As Form = DirectCast(Activator.CreateInstance(objType), Form)
objMsgBoxDialog.Text = "This is form text."
objMsgBoxDialog.Icon = My.Resources.MyIcon
objMsgBoxDialog.ShowDialog()
Thanks.
Hello Hristo,
Sorry for late reply but its working fine. No other questions. Thank you very very much.
Hello Ashish,
I’ve translated Chris’ code to VB.NET and combined with your code snippet and everything works, please see attached sample. What I’ve notes is that you call Assembly.Load() instead of Assembly.GetAssembly(…) as Chris suggested. So I assume that because of this you are not able to achieve your goal.
