Hi
I have an UltraTree (v12.2).
The ViewStyle is set to OutlookExpress to be able to get all the columns from the different levels properly aligned.
One of the column is a checkbox but I need to display the CheckBox only on rows of the first level (other level can leave the cell empty).
How can I achieve that?
It seems that it does the job! Thanks again
Hm, maybe those are leftover checkbox elements that are not getting removed. Right before you return true from the CreationFilter, add this:
parent.ChildElements.Clear();
Let me know if that doesn't help.
Any ideas why I sometimes see some ghost?
As shown on the attached image, only the purple line (level 0) should show a checkbox.
The ghosts appear here and there not always and the same place, sometimes after I do a ExpandAll, sometime when scrolling, ...
The CreationFilter does the trick. Thanks.
I just checked again and I don't have an editor. Here is my code (referencing v.12.2):
//set the ColumnSet UltraTreeColumnSet rootColumnSet = treeHeaders.ColumnSettings.RootColumnSet; rootColumnSet.AllowCellEdit = AllowCellEdit.Full; _columnSelected = rootColumnSet.Columns.Add("Selected"); _columnSelected.DataType = typeof (bool); _columnSelected.AllowCellEdit = AllowCellEdit.Full; _columnSelected.ButtonDisplayStyle = ButtonDisplayStyle.Always;
Really? If I don't assign a CheckEditor to the column, it displays as "true" or "false" on mine.
Anyway, no - it doesn't matter whether you use an editor or not.
