1075
Incorrect export of multiband grid
I discovered an export to Excel is failing in a specific case when using a multiband grid. It's too specific to explain, but my attached sample project demonstrates the problem.
If you run my program and export the grid data to Excel, the rows containing 'Item 1.1.2' and below are placed two cells too far to the right (they should start in column A).
I know the layout is doing unusual things like adding dummy columns in the first band and hiding the column headers of the other bands, but this creates the visual result the product owner requires.
UltraGridMultiBandExportToExcelProblem.zip
