725
Converting UltraCombo to UltraDropDown
I'm currently working on a project that initially used a form to display data in Text Boxes & UltraComboBoxes
I am now trying to convert from using a Form to using an UltraWinGrid in CardView Mode.
My biggest issue for now is replicating all the Filter/Complete behavior I had on the UltraCombo in the new UltraDropDown control for the grid.
In the Form Version I have this in the Form Init routine
        With ucb_EMSName
            .DataSource = _stcodes
            .ValueMember = "Station"
            .DisplayMember = "Station"
        End With
And then the following control init
    Private Sub ucb_EMSName_InitializeLayout(sender As Object, e As UltraWinGrid.InitializeLayoutEventArgs) Handles ucb_EMSName.InitializeLayout
        With ucb_EMSName
            .DisplayLayout.Bands(0).Columns("Station").Header.VisiblePosition = 0
            .DisplayLayout.Bands(0).Columns("Code").Header.VisiblePosition = 1
            .AutoCompleteMode = AutoCompleteMode.Suggest
            .AutoSuggestFilterMode = AutoSuggestFilterMode.Contains
            .CharacterCasing = CharacterCasing.Upper
            .DropDownStyle = UltraWinGrid.UltraComboStyle.DropDown
        End With
    End Sub
This works fine on the form by automatically filtering the drop down list as the user types in the control.
For the Grid version I have tried to replicate it with the following
In the form init routine
        With udd_EMSName
        End With
        With ug.DisplayLayout.Bands(0).Columns("Station")
            .ValueList = udd_EMSName
        End With
And the following control init
    Private Sub udd_EMSName_InitializeLayout(sender As Object, e As UltraWinGrid.InitializeLayoutEventArgs) Handles udd_EMSName.InitializeLayout
        With udd_EMSName
        End With
    End Sub
This simply gives me a 2 column drop down with no filtering.
I know this should be simple but what am I missing?
