In the example I have provided the Name column has CellActivation set to ActivateOnly and CellClickAction set to CellSelect. Once the cell is selected the name disappears or is hidden. Once I leave the cell the name displays again. I have set CellClickAction to CellSelect because I just want the cell selected so the end user can double click on the cell to load a form.
Is there a better or different way I should be handling this?
That fixed it. Thank you.
You don't need a CreationFilter to fix this. The cell text is turning white because of the ActiveCellAppearance which is applied to the grid by default. Just remove it (or Change the ForeColor) and it will work fine.
FAQ:How do I turn off the ActiveRowAppearance so that the active row in the grid does not appear selected.
Hello ,
Thank you for the provided sample, I’ve reviewed your code and its look very well. If I should implement logic for this scenario, I would use IUICreationFilter in order to remove the text of the active cell for particular column (also the same behavior could be achieved with IUDrawFilter), instead to manage the active cell appearance. This appearance might be need for future usage and I wouldn’t want to block it for such simple thing. You could review my approach with CreationFilter in the attached sample, please take your time and choose the best approach for your scenario.
