The bug presented in http://ko.infragistics.com/community/forums/p/80433/406341.aspx is still present. See attached sample.
I have to use CLR 3.5. The application cannot be upgraded.
I ended up using Infragistics 2011.2, which does not present the bug.
IMHO it's a shame that the last version supporting .NET 2.0 - .NET 3.5 is left with a really nasty known bug. I have another application in use, based on CAB and SCSF for WinForms that uses 2012.1 version. The bug didn't occur yet, but I will be a big pain to fix it if it does.
Emanuel
Hello Emanuel,
ehaisiuc said:...at least, provide me the patch so I can apply it on the source code I have already downloaded...
ehaisiuc said:...so I can build the control's library myself
http://ko.infragistics.com/legal/license/ultimate/
Let me know if you have any further questions.
Got it: you can't make the change. But, at least, provide me the patch so I can apply it on the source code I have already donwloaded, so I can build the control's library myself.
I don't want to get in details but it's not feasible to update the Windows XP PCs to .NET 4.0.
As I already explained, we are not able to make changes in version 12.1, but what you could do in this case is to upgrade your current version (to .Net4.0) and also to upgrade all machines with Windows XP using the link below :
http://www.microsoft.com/en-us/download/details.aspx?id=39257
I cannot do that. I have to stay on .NET 2.0 / 3.5. The app is in use on many Windows XP PCs, and there is no way I can switch them all to .NET 4.0.
