1470
Tools not showing up in several Vista machines
we got a strange behaviour, on one Vista machine the tools are not showing up on the ribbon on the mdi parent form and the first loaded child. On other test machines with Vista it works correctly. We installed the machine where it doesn't work correctly new, but the behaviour does not change.
I also debugged on that machine, and there is no exception throwed or something. After generating the tools, i checked the memory and all tools are there with visible==true.
 Any ideas?
Regards
  • 71886
    I believe that this was an issue which has already been fixed. So what you could do is upgrading to the latest service release available for your current version or either download the trial version of Net Advantage 11.2 and test your application against it.
    Please do not hesitate to ask if something comes up.
