175
Rowspan in a UltraGrid filled with a DataTable
I'm trying to do a Rowspan between two cells in a UltraGrid filled with a DataTable.
I have a DataTable where I add some rows, containing string's and int's, and I want to "span" the rows in the first column and group it every two rows.
I'll try to do an example ....
HEADER ->    COL 1             || COL2 || COL3 || COL4 |
ROW1 ->        TEXT               || 1234  ||  1234  ||  1234 |
                     (no separation)  ||  ------  ||  ------  ||  ------  |
ROW2 -->       SPANNED       || 1234  ||  1234  ||  1234 |
Thanks in advance!!
  • 469350
    Verified Answer
    I'm not really clear on exactly what you want here, but the only suport the grid has for spanning a single cell across multiple rows is by using the CellMerging feature. This merges cells that have the same value across multiple rows.
