400
Group first Band Header to second Band
I have a master detail utraWindGrid, bind to a data source. I want to use the band[0] columns header for my second band[1]. I have created UndoundColumns in my band[0] and I choose the hide header columns header for my band[1]. How can I associate them together? This way if I change column order in run time all the columns will change. Also, Is it possible to not repeat them for all group?
Thanks I will try to upload a screen shoot tomorrow.
Gabriel
screen shoot
  • 71886
    Hello Gabriel,
    You could use a code similar to the following in order to achieve the desired behavior:
     private void Form1_Load(object sender, EventArgs e)
                ultraGrid1.DisplayLayout.Bands[1].ColHeadersVisible = false;
                ultraGrid1.DisplayLayout.Override.HeaderPlacement = HeaderPlacement.OncePerRowIsland;
            private void ultraGrid1_BeforeColPosChanged(object sender, BeforeColPosChangedEventArgs e)
                ultraGrid1.DisplayLayout.Bands[1].Columns[e.ColumnHeaders[0].Column.Key].Header.VisiblePosition = e.ColumnHeaders[0].Column.Header.VisiblePosition;
    Please feel free to let me know if I misunderstood you or if you have any other questions.
