1210
AutoCompleteMode = Suggest causes scrollbar to disapear
When I set column's AutoCompleteMode to be either Suggest or SuggestAppend, it looses the scrollbar after the first suggest (assuming the suggest results in less than 8 items).l
I have more than 8 items in the drop-down initially and when I start typing, I get the suggest matches as expected (no scrollbar). Once I set the value or clear the value and then drop-down the list again, I am back to getting full item list but this time there is no scrollbar so only first 8 items are visible. From now on, the only way to get to an item after item #8 on the list is by typing something that brings it in via the suggest.
Is this a known bug?
Trausti
