Dear,
I'm trying to load an xls file using
workbook1 = Workbook.Load(Path)
but this generates an exception
Message: Index was out of range. Must be non-negative and less than the size of the collection. Parameter name: index Stack Trace: at System.ThrowHelper.ThrowArgumentOutOfRangeException() at System.Collections.Generic.List`1.get_Item(Int32 index) at Infragistics.Documents.Excel.Serialization.BIFF8.BiffRecords.STYLEEXTRecord.LoadHelper(BIFF8WorkbookSerializationManager manager, STYLEEXTRecordInfo info, Int32 stlyeIndex) at Infragistics.Documents.Excel.Serialization.BIFF8.BIFF8WorkbookSerializationManager.VerifyFormatsLoaded() at Infragistics.Documents.Excel.Serialization.BIFF8.BiffRecords.EOFRecord.Load(BIFF8WorkbookSerializationManager manager) at Infragistics.Documents.Excel.Serialization.BIFF8.BIFF8WorkbookSerializationManager.LoadCurrentRecord() at Infragistics.Documents.Excel.Serialization.BIFF8.BIFF8WorkbookSerializationManager.LoadWorkbookContents() at Infragistics.Documents.Excel.Serialization.WorkbookSerializationManager.Load() at Infragistics.Documents.Excel.Workbook.LoadBIFF8File(Workbook workbook, Stream stream, IPackageFactory packageFactory, Boolean verifyExcel2007Xml, String parameterName) at Infragistics.Documents.Excel.Workbook.LoadHelper(Stream stream, WorkbookFormat format, String parameterName, IPackageFactory packageFactory, Boolean verifyExcel2007Xml) at Infragistics.Documents.Excel.Workbook.Load(String fileName, IPackageFactory packageFactory, Boolean verifyExcel2007Xml) at Infragistics.Documents.Excel.Workbook.Load(String fileName, Boolean verifyExcel2007Xml) at Jdn.ICat.Tasks.ImportExcelFoodOrder.ReadExcel(String p, FoodOrder foodorder) in D:\DOTNET\Local\Logistics.iCat\DEV\iCat\Jdn.ICat.Tasks\ImportExcelFoodOrder.vb:line 81
I found a work around for my user:
Open the file in excel 2010 and do a save. The file extension is still .xls so i don't understand what good this does.
Is there another work around or fix ?
PS :Infragistics4.Win.v12.1
version :12.1.20121.2054
Hey,
You were right, i just tested it with the latest version and it worked. However due to some restrictions at work I cannot just simply switch to the latest version ( even though we have the licenses)
But i just spoke to my head of development and he said I can use the latest infragistics4.Document.Excel.V13.1 dll .
Do you see any problems using one dll from 13.1 and all others from 12.1 ?
Dimitri
Hello Dimitri,
Thanks for attached stack trace. In that version we implement many fixes, so my first suggestion is to upgrade your current version with the latest available service release 12.1.20121.2135. If you have the same issue after this upgrade, I`ll ask you to upload your excel file that reproduce the issue. By this way, we will be able to debug the source code to find the reasons for the issue.
If you have any questions, feel free to write me
