Dear Infragistics UltraGrid Windows Forms Power Users --
Please help.
I need to know how to create a grand-total row when there are 2 bands and each band already has a sub-total row.
So, I have sub-totals of given column, showing the sub-total per-band.
But, at the bottom of the whole grid, I want the grand-total, which would be the sum of each sub-total-per-band, etc.
It currently looks something like this...
Currently, this is how I am adding the data-columns and the sub-total columns....
//Add a column.
myUltraDataColumnTemp = targetChildBand.Columns.Add(columnKey: DBField._Cost___Component.OD_Component1, dataType: typeof(decimal)); targetGrid.DisplayLayout.Bands[myUltraDataColumnTemp.Band.Key].Columns[myUltraDataColumnTemp.Key].Header.Caption = "OD Component 1";
//Add a summary for the column. mySummaryBandTemp = targetGrid.DisplayLayout.Bands[myUltraDataColumnTemp.Band.Key]; mySummaryColumnTemp = mySummaryBandTemp.Columns[myUltraDataColumnTemp.Key]; mySummaryBandTemp.Summaries.Add(SummaryType.Sum, mySummaryColumnTemp); mySummaryBandTemp.Override.SummaryDisplayArea = SummaryDisplayAreas.GroupByRowsFooter | SummaryDisplayAreas.Bottom;
...and that works great and I like it BUT I do not know how to add the grand-total row....
I have done some searching online and but I could NOT find my answers here...
http://ko.infragistics.com/community/forums/p/72749/369704.aspx
http://help.infragistics.com/Doc/WinForms/Current/CLR4.0/?page=WinGrid_Display_Summary_Footers_for_All_GroupBy_Rows.html
http://stackoverflow.com/questions/18053754/displying-grand-total-of-groups-in-grid
http://help.infragistics.com/Help/Doc/WinForms/2011.2/CLR2.0/html/Infragistics2.Win.UltraWinGrid.v11.2~Infragistics.Win.UltraWinGrid.UltraGridOverride~SummaryDisplayArea.html
...so do you know a quick and easy way to add a grand-total row?
Please advise.
Thanks.
-- Mark Kamoski
It depends what you mean by "Row totals". Summaries will automatically recalculate if their dependencies have changes and the same goes for formulas. If you are doing some king of calculated totals in the InitializeRow event, you can fire InitializeRow to re-fire by calling grid.Rows.Refresh(FireInitializeRow).If it's something else or you are using some other event, I'm not sure. :)
How can i update rows totals in parent bands after cell changes in child bands
Hi Mark,
What you have to do is promote the sum of the child band into a cell in the parent band, then sum the parent column.
private void ultraGrid1_InitializeLayout(object sender, Infragistics.Win.UltraWinGrid.InitializeLayoutEventArgs e) { UltraGridLayout layout = e.Layout; UltraGridBand band0 = layout.Bands[0]; UltraGridBand band1 = layout.Bands[1]; band1.Summaries.Add("Column 2 Summary", SummaryType.Sum, band1.Columns["Column 2"]); // Create an unbound column in the parent band that will contain the sum of the children // of each row UltraGridColumn summaryColumn = band0.Columns.Add("Summary"); // And a grand total summary. band0.Summaries.Add(SummaryType.Sum, summaryColumn); } private void ultraGrid1_InitializeRow(object sender, InitializeRowEventArgs e) { if (e.Row.Band.Key == "Band 0") { // Populate the unbound cell in the parent band with the value of the sum of the child rows. e.Row.Cells["Summary"].Value = e.Row.ChildBands[0].Rows.SummaryValues["Column 2 Summary"].Value; } }
