Hi.
I just want to test the ultraToolBar tool click event but it is not working :(
This is my processing sequence.
1. create window application on C#.
2. add UltraToolBarManager on form1 and make new toolBar - UltraToolbar1
3. add tool button 'ButtonTool1' (image & text)
4. I wish, when I click tool button then 'test' message pop up.
follow is my code that it does not working.
Hope... any body can help me to solve it.
using System;using System.Collections.Generic;using System.ComponentModel;using System.Data;using System.Drawing;using System.Text;using System.Windows.Forms;
namespace WindowsApplication1{ public partial class Form1 : Form { public Form1() { InitializeComponent(); }
private void ultraToolbarsManager1_ToolClick(object sender, Infragistics.Win.UltraWinToolbars.ToolClickEventArgs e) {
switch (e.Tool.Key) { case "ButtonTool1": MessageBox.Show("test"); break; }
This shuold work, make sure the InitializeComponent() method adds an event handler to the ToolClick event of the toolbars manager and that handler is ultraToolbarsManager1_ToolClick
